Release Notes: Cireson Asset Management v6
These release notes have been deprecated, please see the release notes at https://downloads.cireson.com
2016/11/3 - v7.5.2016.148, 7.5.2012.148
1. SCSM2016 Compatibility release
2016/09/27 - v7.5.60.148
Fixes:
1. Updated license client dll - Requires Console Licensing app v7.5.0.92 or greater.
2. [IR51898] Data in relationship type Cireson.AssetManagement.SoftwareAssetHasLocation breaks Install Count in Software Asset workflow
3. [IR51246] Bugs in the consumables section.
-Bring back Increase and decrease Available count
-Maximum Available Level will not going to affect available count
4. [IR50450] Double click on an empty related field within AM gives an error
5. [IR36493] - All Software Assets view in console shows wrong date/time format for " Last Updated" column
6. [IR50148]  Spelling Issues in AM Settings Screen
7. [IR50141]  HW Asset - Set Received date task has extra checkbox
8. [IR49732] Update Software Asset console task throws propertyname exception and fails to update install counts
9. [IR52393] Software Asset Update Task is broken
10. [IR43564] Catalog Item Cost displaying $
11. [IR48307] Software Asset Form - Currency is displayed based on the computers regional setting
12. [IR38182] - Copy License Assignments task is not working
13. [IR41428,IR50456] Windows 10 - When language is set to Norweigan you are unable to change datetime fields on Support & Maint
14. [IR48548] Windows 10 - PO form date validation is broken for Windows 10 when using Finnish language
2016/04/26 - v7.5.60.144
Fixes:
1. General fix - License client has been upgraded to 1.0.5892.25169
2. Consumable fixes
- Fixed available count calculations
- Removed auto calculate checkbox in consumables -- No longer needed.
- A dialog box will now appear if any of the counts are changed on a consumable.  It will prompt for an entry in the consumable action log.
    - Consumable tasks "Decrease Available Count", "Increase Available Count", and "Update Consumable" have been removed, as they are longer needed.
3. Asset Management Import - LDAP queries with custom mappings were only updating the first object retrieved.  AMI will now update all objects appropriately.
4. License and Software Asset fixes:
- If a license is updated through the Software Assets form updated information will now automatically show in the software asset without a refresh.
- If allocated seats are changed on license it will automatically recalculate seats remaining.
5. General fix - All AM instance pickers will NOT show objects with a status 'Pending Delete'.
6. Workflow fix - Adding the following registry entry will keep a workflow from deleting model or manufacturer data on a software asset or hardware asset:
- Key: HKEY_LOCAL_MACHINE\SOFTWARE\Cireson\Asset Management Value, String Value Name: DontRemoveModelManufacturerData, Value: 1
7. Workflow fix - Software assets will only relate hardware assets that share the same location.  If no location is specified on the software asset, then no location matching is performed.
8. Deleted items showing in Asset Management search results
9. Product key field will not show up on a license and respect the proper AM settings.
2016/02/09 - v7.5.60.137
Build 133 Notes
New Features:
1. Purchases are now called 'Line Items' to support our new procurement process.  You'll see this change throughuot the UI with Purchases now labled 'Line-Item [Purchase]'.
2. The PO form now shows all Line-Items on the General tab of the form.
3. The PO form includes a Shipping tab.  You can associate a location as a shipping destination and include shipping costs.
4. The PO form can auto calculate a total cost from the total of all line items and shipping costs.
5. The Line-Item form now has a 'Financial' section on the General tab.  The total cost of a line item is auto-calculated from Units, Unit Costs, Additional Charges, Location Tax Rate.
6. All "Cost" fields throught the AM UI will now adhier to the system set locale.
7. The association of Model/Manufacturer enum lists during the HWA workflow is now semi-intelligent.  Instead of looking for exact matches, it will attempt to make the best match from the available enum list items.
ie.  If the Manufacturer reported from ConfigMgr is 'Dell Inc.' and the Enum list item is 'Dell', a match will be made.
8. Users can now set an inventory date on a hardware asset.  The ConfigMgr last inventory date is also visible on the hardware asset form if an associated CI is related.
Fixes:
1. Some relationships between classes were not viewable between each other.  Ex: Relate a PO in a support contract.  The same support contract will not be visible inside the PO.  This has been fixed.
2. The Software Asset workflow no obeys 'Don't Remove Model & Manufacturer data' setting.
3. In previous versions, if a contract was superceded before its end date the days left calculation would not account for the remaining days left on the superceded contract.  This has been fixed.
4. In previous versions any 'New' button a form would create a new instance in Service Manager (If OK or Apply was clicked), but it would not automtically relate the new instance to the parent instance.  The behavior of the 'New' buttons in Asset Management has changed slightly.
In this verison the 'New' button behaves more like the rest of the console, for instance, clicking the 'New' button does the following:
- Creates a new instance of the class (!!!Does NOT create an instance in Service Manager!!!) and presents the form.
- The parent instance is related to the new child instance automatically.
- If OK/Apply is clicked on the child form, the child instance is automatically related to its parent.
- If OK/Apply is clicked on the parent form, the parent instance is updated and the child instance is created in Service Manager.
This behavior is exactly how Activites work with Work Items.
Build 135 Notes
Fixes:
1. [IR35215] - [IR35215] - SCSM Console crashes when applying changes to available count of consumable
2. Consumable 'Available Count' will retain its input value
3. The PurchaseHasLocation now has a proper display name.
4. The Purchase Has Support Contract relationship has been renamed to Line Item [Purchase] has Support Contract
5. The PurchaseTaxRate property on the Line Item form now has a display name.
6. Relationship Purchase Order Shipping Location has been renamed to Purchase Order Has Shipping Location to fit in with standard AM naming convention
7. All list views throughout AM respond to double click when an item is selected.
8. A minor refactor was done to contract 'DaysLeft' calculations on the form and the workflow.
Build 137 Notes
1. All new vNext elements now contain translations for DEU, SVE, and PLK supported languages.
2015/10/07 - v7.5.60.118
1. Added new Catalog Item Workflow setting of "Never overwrite any existing Hardware Asset property".
2015/09/30 - v7.5.60.112
1. Added additional server licensing features.
2015/08/26 - v7.5.60.110
1. Updated to support new server based licensing. Cireson Console App Licensing is required.
2015/08/12 - v7.5.60.109
1. For Software Assets with a null or blank version pattern, Software Metering data is now pulled correctly from SCCM.
2015/03/06 - 7.5.60.108
1. Export function on Software Asset form for metering data has been fixed. CiresonAssetManagement.mpb is the only change in this release.
2015/02/10 - v7.5.60.106
1. On the Software Asset form, Finance Tab, Licensing section, the "Seats Remaining" column was showing the value for "Seats".
2015/02/05 - v7.5.60.105
1. When setting a custom key for new Hardware Assets such as Serial Number or Asset Tag, this feature unintentionally only worked if the selected value was also ticked under the properties to copy from SCCM. This release updates Cireson.AssetManagement.Workflows.dll to v7.5.60.106 so that the custom key feature for these 2 properties works regardless of whether or not they are being copied to the Hardware Asset properties.
2015/01/13 - v7.5.60.104
1. Updated Swedish language pack.
2. Added some additional Data Warehouse fact tables.
2014/12/20 - v7.5.60.103
1. Added consumable template for portal.
2014/12/16 - v7.5.60.102
1. Additional logging added to the Hardware Asset Sync workflow with regard to model/manufacturer mapping plus a couple of changes to prevent workflow failures.
2014/12/03 - v7.5.60.100
1. Consumables have been added.
2014/11/28 - v7.5.60.27
1. Fixed Related Items not working on the Licence form.
2014/11/26 - v7.5.60.26
1. Updated CiresonAssetManagement.mpb for Portal.
2014/11/11 - v7.5.60.24
1. Informational texts for days left on contracts on the Hardware Asset form are now correct.
2. The superseded contract mechanism caused contract forms to not update automatically when they were being created or if the status was null.
2014/11/04 - v7.5.60.22
1. Interim, pre-Q4 release to add support for the V3 portal.
2014/09/24 - Cireson.AssetManagement.Workflows.dll changed only (v7.5.60.10)
1. Changes to the Catalog Item workflow for problems with error messages related to Guids.
2. Software metering workflow now works if computers are created via an SCCM connector and do not have a SID but NetbiosComputerName on the computer CI in the CMDB must match Netbios_Name0 in SCCM.
2014/09/22 - v7.5.60.9
1. Sometimes a licence would get stuck on "Expiring" status and never be changed to "Expired". 2. Expired status licence seats no longer count towards Purchase Count.
2014/08/26 - v7.5.60.8
1. Rebuild of 2014 Q3 latest release to incorporate previous post-Q3 patches.
2014/08/14 - v7.5.60.2 (Cireson.AssetManagement.Workflows.dll version)
1. Software Asset workflow now correctly allows processing of assets if PurchaseCount=0.
2014/08/14 - v7.5.60.1 (Cireson.AssetManagement.DataWarehouse.Reports.mpb version)
1. Reports may show duplicate rows if ENU and another Language Pack DisplayString exist.
2014/07/15 - v7.5.60.4
1. V6 initial release.
2. On Windows 8 or 8.1, an exception may be thrown on the admin settings which has been fixed.
3. Invoices can have related POs.
4. Invoices can have related Purchases.
5. POs can have related Purchases.
6. Invoices, POs and Purchases have a new Contracts tab where contracts related to these purchases may be added as required.
7. Notice Events have an option to send to the Contract Custodian if the event is relating to a contract or asset via a master contract.
8. New task targetted at the User class to show all related assets.
9. Invoice Status added.
10. Rewording on Software Metering connectors to make functionality clearer.
11. Licences can have Purchases.
12. Standards, the Note property was not saving.
13. Cost Centers can have child/parent relationships.
14. New multi-select task for Hardware Assets to set same disposal date/reference.
15. Fixes for decimal properties not using/working for localised decimal group and separation characters.
16. When copying cost from a related Catalog Item for the Hardware Asset Sync Workflow, currency is also copied.
17. The Software Asset Update Workflow has been rewritten to greatly reduce load on Microsoft SQL Servers.
18. Localisation updates.
19. Software Assets have an option to exlude them from authorisation boundaries.
2014/05/23 - v7.5.50.5
1. Date Pickers on some forms (Lease and Warranties, for example) were not behaving correctly when Thai date formats were in use.
2. If a contract has a status of "None" (normally if the start date is greater than the end date) the days left property is set to 0 (zero).
2014/05/20 - v7.5.50.2
1. Notes can now be saved on Standards. New property called StandardNotes has been added.
2014/04/17 - v7.5.50.1
1. Order of admin setting tabs reordered to match order of documentation.
2. New admin setting for Software Asset Update workflow of "If none of these are defined for a Software Asset, count anyway", which is a sub-setting for "Only count a computer if Authorised Cost Center, Organisation or Location matches".
Note - these admin options for organisational boundaries do not have any effect on, or relationship to, the Authorised/Unauthorised lists and counts.
3. New workflow "Notice Event Workflow" with admin settings for setting a schedule.
4. New admin setting on misc. tab for "Show Auto Renew on the Notice Event form". This property may be shown and used with customer custom workflows.
5. New class - Notice Event. Notice Events are primarily designed for use with contracts but can be used with any CI class. Notice Events can be used to send out notification emails based on a Due Date, or Contract End Date or Master Contract End Date of related Hardware Assets on Contracts.
Note - SCSM Admin must create required notification templates first and assign "Edit" task for Notice Events to required Analysts via a User Role.
6. New class - Standard. Standards can be used to record Hardware and Software requirements, for example, for new starters.
7. Both Purchases and Purchase Orders have Type and Purchaser.
8. Contracts may be superseded by newer contracts. This data is recorded on the Finance tab.
9. New task - "Update Superseded Asset Support Contracts".
10. New task - "Update Superseded Hardware Asset Leases".
11. New task - "Update Superseded Hardware Asset Warranties".
The above 3 tasks will update related asset contracts for the selected superseded contract(s).
12. New Task - "Update Lease".
13. New Task - "Update Warranty".
14. New Task - "Update Support Contract".
The above 3 tasks update contracts similar to the Contract Status Update workflow.
15. New Task -"Add Affected Software Asset" for Work Items, same as existing "Add Affected Hardware Asset" task.
16. Hardware Assets have "Expected End Date" property.
17. New View - "All Software Assets with CPU Licensing".
18. New View - "All Software Assets with Downgrade/Upgrade Counts".
19. New View - "All Standards".
20. New View - "All Notice Events".
21. New View - "My Notice Events".
22. New View - "My Purchases".
23. New View - "My Purchase Orders".
24. Licences have new properties for "Allocated Seats" and "Seats Remaining".
25. Licences have new "Assignment" tab that can be used to record assigned Computers and Users with options to count towards "Seats Remaining".
26. Software Asset form has been reworked to place all options in one place.
27. Software Assets can now have Downgrades and Upgrades, related Software Assets are added tot he "Downgrades & Upgrades" tab and new properties for Total Purchase Count, Downgrade Licences, Downgrades Available, Upgrade Licences and Upgrades Available have been added.
28. Authorised counts have been added to the Software Asset form.
29. Software Assets now have the option to use "named" licences which are Computers and Users recorded on the Related Assets tab. This feature can be used for "install less" software or similar requirements.
30. Software Assets can use Logical or Physical CPU licensing.
31. On the Software Asset form, "Is Operating System" has been renamed to "Enable Operating System Licensing Mode".
32. Software Assets have an option to automatically set Purchase Count from related Licence Seats.
33. Workflow and Task changes for new Software Asset and Licence features.
34. Data Warehouse changes for new relationships.
35. Preview Form changes for new properties and relationships.
36. New Software Asset List report which has columns for all counts, options and licensing modes.
37. Software Asset Type added to existing Software Asset List report.
38. Existing Software Asset List report now groups by currency and includes sub-totals.
39. Software Asset Detail report has been reworked to include new General tab properties.
40. Authorise and Unauthorise buttons added to certain computer lists on the Software Asset form.
2014/02/26 - v7.5.32.8
1. Updated Polish Language Pack.
2014/02/21 - v7.5.32.7
1. Fixed validation issue on Software Asset form if Software Metering was not enabled and a bundle containing more than one pattern was created.
2014/02/10 - 7.5.32.6
1. Updated Polish (PLK) language pack.
2014/02/04 - v7.5.32.5
1. Added Polish language pack.
2014/02/04 - v7.5.32.2 (Software Metering only)
2014/01/14 - v7.5.32.4
1. Version in settings now shows new versioning.
2013/12/19 - v7.5.32.2 (v3.2)
1. Software Patterns can no longer contain ampersands ("&") when saving a Software Asset.
2. New option to remove catalog item relationships for retired or disposed Hardware Assets.
3. Software Assets - matching can now be done via new Authorization lists for Cost Centers, Organizations and Locations. If relevant relationship on the computer related Hardware Asset matches one from the Software Asset then the computer is counted and added. This allows similiar Software Assets per Cost Center, Organization or Location to be setup to keep separate counts for business units. This behaviour is enabled via a new admin setting. The previous, single values for Cost Center, Organization and Location are not used for this check, they must be added to the authorized lists if required.
4. Automatically relating a Location to a Hardware Asset with multiple NICs all on the same Location now works.
5. Software Assets now have a new "Software Library Location" property to store install paths.
6. Hardware Asset has a new Assigned Date property.
7. Hardware Asset age is now shown on a label above Received Date.
8. New option to change Hardware Asset to name of related Config Item if matched via Serial Number.
9. Hardware Asset Status, Hardware Asset Type and Software Asset Status were displayed with different names on forms, views and properties. These are now all "HW Asset Status", "HW Asset Type" and "SW Asset Status" for consistency and to avoid conflict with existing "Asset Status" property.
10. Hardware Asset views redone to remove columns with converters for contracts so sorting and filtering will now work (there are now extra regular columns).
11. New Purchase Order report added under “Reporting\Cireson Asset Management\Purchase Order Reports”.
12. Currency list added. Recommendation is to use standard 3 letter currency codes such as NZD, USD, GBP, EUR due to width limitations. All views, forms and preview panes now show this value.
13. On the Catalog Item preview pane and form, the image will now scale to the size of the form.
14. Delete Subnet task added for administrators.
15. Transfer Hardware Asset task added. Transfers selected relationships from source Hardware Asset to new target Hardware Asset.
16. Cost Center added to "All Software Assets" view.
17. When opening Software Assets, computers on the Related Computers list, but not on the Authorized Computers list, are added to a new Unauthorized Computers list. For customers with a very large number of related assets, if this new feature causes performance issues opening the new form, this feature can be turned off via admin settings. In this case, the "Refresh" button above the new list can be used when required or when using the "Update Software Asset" task. This list is not stored in the database, it is for reference only, but can be exported to Excel if required.
18. In the past, certain customers have had issues with triggering updates on a form when a Warranty, Lease or Support Contract was selected, or when a Date property was updated. These problems should now be fixed.
19. Decimal values can now contain commas. Commas will be displayed when the form is next opened, on the preview pane and views, or can be typed in as a part of the data.
20. WPF problems causing the cursor to jump around when entering decimal values are now fixed.
21. Admin settings now correctly show a progress bar when saving after changing workflow values, instead of "hanging" for several seconds.
22. There is a new admin setting on the Hardware Asset Sync Workflow to ignore Configuration Items where the display name starts with "\\". This can be used to ignore AD published printers.
23. Some localization strings were missing, this also affected the Software Metering Management Pack which has been version increased.
24. Data Warehouse relationship facts added for recently added relationships.
25. Purchase Orders now have a "Purchase Order Status" property. Values for this new list can be defined via Administration\Lists.
26. Purchase Order Detail Report has been added for use with the new list report.
27. Software Assets have new properties for Authorized and Unauthorized computer counts that can be used in views or to trigger workflows. These values are maintained by the Software Asset Update Workflow.
28. Software Assets have new Authorized Install Count property for use in views and workflows.
29. "Add Affected Hardware Asset" tasks added for Incident, Problem, Change Request and Service Request classes. These new tasks must be enabled for non-admins via a User Role.
30. Admin setting for Software Asset Update workflow to exlude retired or disposed assets have been extended to exclude in-stock assets.
31. Hardware Assets have a new list on the Related Assets tab that shows related Software Assets (if applicable) for the associated Config Item.
32. On the Software Asset form, the Authorized Computers list now includes a column for the related Hardware Asset name.
33. New admin setting for the Software Asset Sync Workflow to remove a computer as an authorized computer if its relatd Hardware Asset is retired, disposed or in-stock.
34. "Related" object list views, when clicking "Add", now show the current items on the instance picker and can be removed or added to.
35. Purchase has Purchaser relationship added to Purchase form, Purchase Preview form and Data Warehouse.
2013/11/1 - v7.5.31.28
1. Locations can now have a parent Location and have a new "Levels" tab showing child Locations.
2. Organizations can now have a parent Organization and have a new "Levels" tab showing child Organizations.
3. Added DisplayString for Support Contract form.
4. Added DisplayString for Purchase Form.
5. Software Metering (v7.5.31.5) - added missing wizard titles when creating connectors.
2013/10/30 - v7.5.31.4 (Software Metering only)
1. Software Metering connection now checks v_MeterData view and not SitesInfo.
2013/09/26 - v7.5.31.9
1. Fixed issue caused by v7.5.31.6 item 1, warning was shown when updating Hardware Assets, now only shown when creating.
2. The Hardware Asset Sync Workflow will now work with multiple subnet masks and IP address, skipping IPV6 ones, when attempting to find a Location via a Subnet.
3. Subnets on the Location form now show the IP address range.
2013/09/17 - v7.5.31.7
1. Certain changes made to the Software Asset form and Software Asset Update workflow to allow Software Assets to be imported with Purchase Count = 0.
2013/09/10 - v7.5.31.6
1. When creating a new Hardware Asset with an existing name, Analyst is now warned and has the option to create or not.
2. Fixed a problem if the option to remove requirement for Serial Number or Asset Tag on the Hardware Asset form was enabled. When this form was first opened, the option did not work.
2013/09/10 - v7.5.31.4
1. Updated German Language Pack.
2013/09/02 - v7.5.31.3
1. Release of v3.1.
2. Added Swedish Language Pack.
3. Fixed Catalog Item view which was showing Model instead of Manufacturer.
4. Further changes to allow Hardware Asset instance picker changes to trigger form updates.
5. Added German Language Pack for Software Metering.
2013/08/07 - v7.5.3.6
1. Asset Status on Hardware Asset views will now sort and search correctly.
2013/07/18 - v7.5.3.4
1. On certain systems, the Hardware Asset form would not update contract information.
2013/07/16 - v7.5.3.3
1. Export Selected Items tasks added for Licenses, Purchases and Catalog Items.
2. Web Site text boxes on Catalog Item and Vendor forms MaxLength extended to 256 characters to match class property lengths.
2013/07/12 - v7.5.3.1
1. Minor change to Hardware Asset form.
2013/07/07 - Initial Release of v7.5.3.0, previous release v7.5.2.1.
1. Days left is now set to 0 when a contract is set as a master.
2. Data Warehouse extensions updated with new classes, relationships and dims.
3. Permissions tool updated for new classes.
4. Forms now apply textbox styling if used in the Authoring Tool.
5. Properties bound to integer or decimal values can now be cleared successfully on forms and are set to null.
6. The Update Contract Status workflow was setting Contract Status to "None" instead of "Master" for Master Contracts.
7. When adding instances to ListViews, relationship data did not populate until the form was reloaded.
8. Several new Type Projections have been added for new workflows and options.
9. Some form buttons did not obey admin setting restriction for create instance buttons.
10. Related Hardware Assets for contracts on the Update Contract Status workflow are now committed in one transaction.
11. Workflow MaxRunningTime is now set to 18000 (5 hours).
12. Certain Export tasks exported blank relationship data.
13. Almost all ListViews now have Add and Remove instance buttons, unless this will cause problems, such as on the contract forms which have remove only. Removing instances from the Contract forms may require the Contract Status Update Workflow to run to reflect changes correctly.
14. All relationships on all preview panes can now be double-clicked to open the target.
15. Contract Status Update workflow performance has been improved.
16. Hardware Asset Sync workflow performance has been improved and is now almost 3 times faster when creating new Hardware Assets. Results taken by creating 10000 Hardware Assets before and after the change.
17. Hardware Assets can now have related Support Contracts.
18. New views added for Hardware Assets with Support Contracts (Warning and Expired).
19. Updated Hardware Asset preview pane to match order of properties on main form and include Contract Status (also added Support Contract).
20. Cost on Finance tab for contracts had incorrect label, renamed from Asset Cost to Contract Cost.
21. Admin settings dialogue will now shrink to fit on smaller resolution display devices based on the primary screen size.
22. Commit batch size added to settings. The default is 100. This is the batch size that a workflow must reach before committing the current transaction. This is a performance tuning option. A smaller batch size can result in slower workflows, and a larger one possibly faster, but larger ones will may require more RAM on the workflow server and TEMPDB on the SQL server to commit the transaction.
23. Forms with Create buttons now size better so that labels don’t truncate unless the form is very narrow and the label is long.
24. Fixed validation issues on the Software Asset form when switching between bundled/not bundled.
25. Software Metering features have been added, Software Assets can now show and use metering data from SCCM. See online documentation for further details.
26. On the Software Asset Form, the label in English for “Warning Threshold %:” has been changed to “Warning Threshold Used %:” to avoid confusion over if, for example, this should be set to “10” or “90” for 90% of the purchase contract used to trigger the warning status.
27. Associate Primary User tasks mistakenly set custodian when run from the Software or Hardware Asset forms.
28. Organizations – Location renamed to “Primary Location” and new “Locations” tab added. Multiple locations can now be related to a single Organization.
29. Software Asset counts no longer include “pending delete” status computers.
30. "Master Contract Renewed On" added to Hardware Assets, can be used to replace "Received Date" functionality without resetting this value when renewing a contract.
31. Manufacturer and Model on the Hardware and Software Asset Forms can now be enums, via a new admin setting.
32. Website added to Vendor and all forms showing a Vendor.
33. Purchase class added for Software Assets, multiple sets of "Finance" tab data can now be added.
34. Catalog Item class added for Hardware Assets and new workflow to transfer selected properties.
35. Subnet class added, can be related to Locations, for automatically setting Hardware Asset location based on IPV4 address and subnet mask.
36. New reports added, there are now 8, and existing Software Assets and Hardware Assets list reports now have many more selectable paramters.
37. New Cubes Management Pack, adds 2 new cubes for Hardware Assets and Software Assets classes.
38. Hardware Assets can now be related to other Hardware Assets, for example, Mobile Phone related to SIM card.
39. Can now select which SCCM properties to sync to Hardware Assets.
40. New look admin settings with several new options, please see online documentation for further details.
41. Software Assets have new "Is OS" checkbox. Operating Systems can be queried from existing "Operating System" class populated via AD Connector without use of SCCM connector.
42. Certain view columns had incorrect labels.
43. Create instance tasks added to main "Asset Management" folder (recurses).
44. New features for Software Assets to filter out unwanted computers from counts.
