Add Content
On the drawer taskbar, click on Content button
Select Chart Widget
When the list of available widgets appear, select Chart Widget
Edit Widget Settings
To configure the newly added table, click on the Edit Widget Settings Icon on the upper right corner of the widget.
On the settings page, you can do the following:
- Give the chart its own Title and Description (Enter translations for other languages by clicking the Enter Translations button)
- Select an existing Saved Search as the source of your content. Alternatively, you can create a new save search by click on the Create New Saved Search link
- Select a property from the Group By dropdown to group the results. The dropdown will contain all the fields or columns returned by the select query. This is also enabled only when a saved search content has been chosen.
- NOTE: It is a requirement to select a property to group by. Chart’s data aggregation depends on the selected property.
- Select the Type of chart you want to use.
- Optionally, you may check on the Display Selected Item Details option to enable the chart drill-through option. When this is enabled, you can click on a particular chart series and be to see the work item details in a grid or table format.
Click on Apply to refresh the chart.
Save Page
On the drawer taskbar, click on Save to save the changes on the page.
Example
Here is an example on how the widget should look like when using a Saved Search for all Incidents displaying each different category
