How To: Add A Count Widget
Add Content
On the drawer taskbar on a navigation page, click on Content button
Select Table Widget
When the list of available widgets appear, select Work Item Count Widget
Edit Widget Settings
To configure the newly added table, click on the Edit Widget Settings Icon on the upper right corner of the widget.
On the settings page, you can do the following:
  • Give the widget its own Title (Enter translations for other languages by clicking the Enter Translations button)
  • Add a Subtitle and/or Description (Enter translations for other languages by clicking the Enter Translations button)
  • Select an existing Saved Search as the source of your content. Alternatively, you can create a new save search by click on the Create New Saved Search link
  • Define a Threshold condition that will trigger count value's color to change. Currently, the available threshold operators are: Is equal to, Is greater than, Is less than, Is greater than or equal to, Is less than or equal to
Click on Apply to refresh the widget
Save Page
On the drawer taskbar, click on Save to save the changes on the page.
Example
Here is an example on how the widget should look like when using a Saved Search for number of Service Requests in the status of In Progress, including a subtitle and a colour when above 5
