Dashboard chart widgets are updated with a functionality to customize chart colors. You can now define your own colors on the chart by specifying a color for each series on the chart.
Saved Search Chart
- Fill in title
- Fill in description
- Select a saved search query
- Select a group by property. When a property is selected, a new section called “Series Color” will be displayed (as highlighted in red below). This is where you can assign a color to a specific series. Initially, each series are given random colors.
- On the Series Color section, clicking on the colopicker dropdown will display all the available colors. Select the desired color by clicking on it.
- Select a chart type
- Click on Apply to save chart configuration changes
SQL Chart
- Fill in title
- Select a data source
- Select or create a new query
- Select a property or column which will correspond to the chart’s series label. When a property is selected, a new section called “Series Color” will be displayed (as highlighted in red below). This is where you can assign a color to a specific series. Initially, each series are given random colors.
- On the Series Color section, Select a number property or column which will correspond to the chart’s plotting value
- Clicking on the colopicker dropdown will display all the available colors. Select the desired color by clicking on it.
ODATA Chart
- Fill in title
- Specify the ODATA endpoint
- Choose a collection
