Exploring OData
The Cireson Platform exposes data in your environment through the Open Data Protocol or OData for short. With OData you have a common way to update and consume data in your Service Manager environment from any number of tools such as Excel, PowerBI, or SharePoint. OData also provides a simple way to filter data to expose it through OData Widgets or through Global Search available on the Portal.
You can use your own platform to get started quickly. Just navigate to http://localhost/platform/api/ where localhost is the name of your Cireson portal server (SSL configurations are supported should you prefer to use HTTPS). Here you can browse the Classes syncing into the platform, as well as their "URL" property. You can use this to build URLs such as:
http://localhost/platform/api/Cached_MT_System_FileAttachmentÂ
http://localhost/platform/api/Cached_MT_System_WorkItem_Incident
http://localhost/platform/api/Cached_MT_System_WorkItem_Problem
http://localhost/platform/api/Cached_MT_System_WorkItem_TroubleTicket_AnalystCommentLogÂ
With each new URL constructed, you can navigate to it to view that particular dataset, its properties, values, and use that information to construct OData filters unique to your environment. Take the following examples:
Filter Examples
Knowledge Articles
LocaleID eq '{{languageCode}}' and StatusStringId eq {{publishedArticleStatusId}}
Incidents
LanguageCode eq '{{languageCode}}' and Status eq 'Closed'
LanguageCode eq '{{languageCode}}' and StatusId eq 'bd0ae7c4-3315-2eb3-7933-82dfc482dbaf'
Analyst Comments
LanguageCode eq '{{languageCode}}' and IsPrivate eq false
File Attachments
LanguageCode eq '{{languageCode}}' and Size gt 5000
Hardware Assets (requires Cireson Asset Management)
LanguageCode eq '{{languageCode}}' and HardwareAssetStatus ne 'Retired'
LanguageCode eq '{{languageCode}}' and HardwareAssetStatus in ('Deployed', 'Loaned', 'In Stock')
Azure Resource Groups (requires configured Azure Monitoring via Operations Manager)
LanguageCode eq '{{languageCode}}' and ObjectStatus eq 'Active'
Additional Resources
Microsoft Article on OData Querying
https://docs.microsoft.com/en-us/odata/concepts/queryoptions-overview
