How To: Promote a View from the SCSM Console to the Portal
The Cireson Portal can utilise custom views that have been created in the SCSM Console.
In order to add a View from the SCSM console to the Cireson Portal, you must first promote the view from within the SCSM console.
Please Note: Anonymous Authentication must be enabled within IIS for Promote View to work.
Promote View Task
Open your SCSM console
Browse to the View you want to Promote and with the View selected, right click it and click the Promote View task:
Initial Setup
The first time you Promote a view (or any time the portal can’t be found) you will be asked to enter the full url of your portal.
Enter your portal’s URL including http:// and if needed a port number and click save:
Once you have entered this URL, you will not be prompted for it again in the future.
Please Note: If you need to change this URL setting, please see KB1116 - How To: Change the Portal View Promotion URL Setting
Promoting a View
Once a connection with the portal has been established you will be asked to select the location in your navigation where you would like to Promote your view to.
A View can only be promoted to a leaf folder, once a leaf folder is selected, click the Promote button to promote the View to the current navigation location.
Folders
From the “Promote View” window you add new Folders to the navigation.  New Folders can either be added to the base or as a sub folder of the Parent Folder (child of the base). All new Folders that are added to the base will also have a sub folder created under it.
Note: Folder names may only contain Alphanumeric Characters & Spaces
Public Views/Folder
Public Views/Folders are views or folders that are Promoted/Created and visible to everyone. (Further access controls can be applied and managed from the Portal Navigation Settings.  If you want your Promoted View to be public, simply click Yes to Create the folder/view as public or No to create your folder as private.
Updating/Re-Promoting a View
You can update or re-promote a view following the same steps as described above, however when you promote the view, you will be prompted to update the existing promoted view or not.
Editing the Folder or View Names
Once you promote a view, any hierarchy or name changes can be done from the Portal Admin Settings > Navigation Settings. More information about Navigation Nodes can be found here: KB23 - How To: Configure Navigation Settings
Views that cannot be promoted
Some views cannot be promoted due to technical difficulties. You may be able to recreate them instead as 'Saved Searches'
CI - All views under Computers folder
CI - All Business Services
CI - All Printers
CI - Software
CI - Software Updates
CI - Users
RA - any view using Reviewers
WI - Runbook Automation Activities
Any view using the Me Token
Any view using a Relative Date Time Token
Views built with Advanced View Editor (from Technet)
Any view that is using a projection with > 2 levels of component nesting
All fields added from view builder Custom Columns
Modifying the Portal View Promotion URL Setting
See: KB1116 - How To: Change the Portal View Promotion URL Setting
