Add-Ins Overview
ARO Clickable Breadcrumbs Download Link
The latest version 1.1.0 of this Add-In can be downloaded here.
Note: This version of the Add-In is built and tested against version 12.0.0 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
ARO Clickable Breadcrumbs Summary
The purpose of this Add-In is to provide a clickable functionality on the already existing breadcrumb on the ARO’s with multiple pages:
The Add-In makes it so that rather than pressing ‘next’ or ‘previous’ to navigate, you can also now click the desired page you want to go to. It will still check for validation, so if you are on page 1, and click page 4, but page 2 is missing required information, then you will be stopped at Page 2.
Testing and Validation
- If experiencing issues, refer to KB Article 2568 here for overall Add-Ins troubleshooting steps
- Run through the Add-In’s functionality with default settings.
- Verify the following:
- In the developer console (open up a browser > dev tools > console), you see that the ARO Clickable Breadcrumbs Add-In is loaded
- As you change settings, go through the above again with browser console open
- Verify no error messages
- Verify your changed settings behave as expected
Examples
This picture illustrates that you can now click on the pages to navigate through the Request Offering.
Versions
