Add-Ins Overview
Asset Management Status Pills Download Link
Note: This version of the Add-In is built and tested against version 12.0.0 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Asset Management Status Pills Summary
By default, the Asset Management forms display a status pill that reflects the Object Status. The Asset Management Status Pills Add-In allows for the status pill to reflect the status of the record itself. For example, the status pill for a hardware asset will reflect the HardwareAssetStatus.
Key
Description
Default Value
ClassesToRender
A comma separated list of classes to reflect statuses for in the corresponding form's status pill
HardwareAsset,SoftwareAsset,Consumables,Invoice,ContractLease,License,PurchaseOrder,SupportAndMaintenance,WarrantyContract
Testing and Validation
If experiencing issues, refer to KB Article 2568 here for overall Add-Ins troubleshooting steps
Run through the Add-In’s functionality with default settings.
Verify the following:
In the developer console (open up a browser > dev tools > console), you see that the Asset Management Status Pills Add-In is loaded
Verify that the Status Pill renders the correct status for each enabled class in the ClassesToRender setting.
As you change settings, go through the above again with browser console open
Verify no error messages
Verify your changed settings behave as expected
Examples
The status pill on the Software Asset form reflects the Software Asset Status of "Approved"
Versions
