Add-Ins Overview
Auto Show History Download Link
Note: This version of the Add-In is built and tested against version 10.2.0 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Auto Show History Summary
The Auto Show History Add-In will change the Portal’s behaviour to automatically load the History of an object when the History tab is clicked, rather than waiting for another click on the Load History button.
eg Hardware Asset, Software Asset, Location etc
eg AD User, Windows Computer and any custom classes
Testing and Validation
- If experiencing issues, refer to KB Article 2568 here for overall Add-Ins troubleshooting steps
- Run through the Add-In’s functionality with default settings.
- Verify the following:
- In the developer console (open up a browser > dev tools > console), you see that the Auto Show History Add-In is loaded
- When opening an Incident and clicking on the History Tab, the Hisotry is automatically loaded
- When opening an Incident and clicking on the History Tab, the Show Hisotry button is not visible
- As you change settings, go through the above again with browser console open
- Verify no error messages
- Verify your changed settings behave as expected
Examples
History Auto Loading on an Incident
Versions
