User Guide: Add-In - Create Related Problem
Add-Ins Overview
Create Related Problem Download Link
Note: This version of the Add-In is built and tested against version 12.2.9 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Create Related Problem Summary
The Create Related Problem Add-In allows users to create a Problem record from an existing Incident and relate the Incident to the Problem. The incident's details are used to fill in the properties of the new Problem.
The incident can be resolved on creation of the problem.
Key
Description
Default Value
ResolveIncident
Set to true if the source Incident should be resolved. Set to false if the Incident should remain in its current Status
false
TemplateId
The Id of the template to use when creating the new Problem record.
426a1051-6198-3cd8-e2e0-44ac79303d6d
Testing and Validation
    1. Verify the following:
      1. In the developer console (open up a browser > dev tools > console), you see that the Dashboard Auto Refresh Add-In is loaded
    1. Verify no error messages
Examples
Example 1
Clicking the Create Related Problem task will create a new PR with the incident related and navigate to the PR.
Having ResolveIncident in the Add-In Settings will set the Incident as Resolved
Versions
Version
Release Notes
Link
1.0.0
First Release.
Download
