Add-Ins Overview
Dashboard Auto Refresh Download Link
The latest version 1.2.0 of this Add-In can be downloaded here.
Note: This version of the Add-In is built and tested against version 12.0.2 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Dashboard Auto Refresh Summary
The Dashboard Auto Refresh Add-In allows dashboard widgets to refresh data on a configurable interval via toggle switch at the top of the page. This only applies to dashboard pages created with the Dashboard Designer.
The Add-In can be configured to allow auto refreshing of all dashboard pages, or specific pages via GUID.
Key
Description
Default Value
RefreshInterval
Sets the time in milliseconds to wait before the page widgets refresh.
60000
DefaultEnabled
Setting this to true will enable the refresh on all dashboard pages by default.
true
ShowOnPages
Leave blank to display the Auto Refresh Toggle Switch on all pages, or list page guids to only show on specific pages.
HideOnPages
This setting is evaluated last. Any page guids added here will not show the Refresh Toggle Switch. This is true if "ShowOnPages" is blank, or if a page guid is added here that is also added to "ShowOnPages".
Testing and Validation
If experiencing issues, refer to KB Article 2568 here for overall Add-Ins troubleshooting steps
Run through the Add-In’s functionality with default settings.
Verify the following:
In the developer console (open up a browser > dev tools > console), you see that the Dashboard Auto Refresh Add-In is loaded
As you change settings, go through the above again with browser console open
Verify no error messages
Verify your changed settings behave as expected
Examples
The above will ...
Toggle the Auto Refresh switch to turn the auto refresh function on or off.
Per Page Add-In Settings
To display the Auto Refresh toggle switch on specific pages, enter the 32 character GUID (including hyphens) in the "ShowOnPages" "VALUE" field. Multiple entries should be separated with only a comma and no spaces.
To display the Auto Refresh toggle switch on all Dashboard pages, leave the "ShowOnPages" "VALUE" field blank.
To not display the Auto Refresh toggle switch on specific pages, enter the 32 character GUID (including hyphens) in the "HideOnPages" "VALUE" field. Multiple entries should be separated with only a comma and no spaces.
Select the Page GUID
You can find the page GUID in the URL for the page you wish to include.
The Dashboard Auto Refresh functionality is automatically disabled when editing a dashboard page, regardless of the toggle switch.
