User Guide: Add-In - Hide Approval Buttons
Add-Ins Overview
Hide Approval Buttons Download Link
Note: This version of the Add-In is built and tested against version 10.2.0 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Hide Approval Buttons Summary
The Hide Approval Buttons Add-In allows more control of the Review Activity form within a parent WorkItem. It can be used to remove the Approve All and Reject All buttons to stop users from bulk approving or rejecting as desired. Further, it can be used to ensure that a user only approves under their own name, effectively removing the Approve on Behalf concept.
Key Description Default Value SRHideForEndUserOnlyApplies the SR functions only to End UsersfalseSRHideApproveRejectAllHides the Approve All and Reject All buttons on SRstrueSROnlyAllowApproversToApproveOnly allows a user to Approve a record assigned to them (or a group they are a member of) on SRs
Also hides the Approve All and Reject All buttonstrueSRReviewersOverrideADGroupAn AD Group (in the format DOMAIN\GroupName) that is allowed to override the above restriction and still Approve on Behalf on SRs CRHideForEndUserOnlyApplies the CR functions only to End UsersfalseCRHideApproveRejectAllHides the Approve All and Reject All buttons on CRstrueCROnlyAllowApproversToApproveOnly allows a user to Approve a record assigned to them (or a group they are a member of) on CRs
Also hides the Approve All and Reject All buttonstrueCRReviewersOverrideADGroupAn AD Group (in the format DOMAIN\GroupName) that is allowed to override the above restriction and still Approve on Behalf on CRs RRHideForEndUserOnlyApplies the RR functions only to End UsersfalseRRHideApproveRejectAllHides the Approve All and Reject All buttons on RRstrueRROnlyAllowApproversToApproveOnly allows a user to Approve a record assigned to them (or a group they are a member of) on RRs
Also hides the Approve All and Reject All buttonstrueRRReviewersOverrideADGroupAn AD Group (in the format DOMAIN\GroupName) that is allowed to override the above restriction and still Approve on Behalf on RRs
Testing and Validation
    1. Verify the following:
      1. In the developer console (open up a browser > dev tools > console), you see that the Hide Approval Buttons Add-In is loaded
      2. When viewing a Review Activity within a parent Servce Request, Change Request and Release Record, the Approve All and Reject All buttons should be hidden
      3. When viewing a Review Activity within a parent Servce Request, Change Request and Release Record, when selecting a Reviewer that is not you, the Approve and Reject buttons should be disabled
    1. Verify no error messages
Examples
With HideApproveRejectAll settings set to true, the Approve All and Reject All buttons are missing meaning that bulk Approvals or Rejections cannot be made.
With OnlyAllowApproversToApprove settings set to true, the logged in user can only approve their own Review record. Selecting another name means the Approve and Reject buttons are disabled. If you have a group as the reviewer, it can only be approved by members of that group.
The override group can be used to override the above function with a group of Super Users who can still approve on behalf.
Note: By default, all these will apply to End Users and Analysts. To apply only to End Users set the HideForEndUserOnly setting per WorkIem type.
Versions
