Hide Out-of-Box Download Link
The latest version (1.1.0) of this Add-In can be downloaded here.
Note: This version of the Add-In is built and tested against version 10.2 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Summary: Hide Out-of-Box Tasks
The Hide Out-of-Box Tasks Add-In allows Portal Administrators to specify tasks they wish to hide on each out-of-box work item and configuration item form.
Testing and Validation
- If experiencing issues, refer to KB Article 2568 here for overall Add-Ins troubleshooting steps
- Run through the Add-In’s functionality with default settings.
- Verify the following:
- Open up browser > dev tools > console and verify that the "Hide Tasks" add-in is loaded
- As you change settings, go through the above again with browser console open
- Verify no error messages
- Verify your changed settings behave as expected
Examples
Example syntax for each setting: "Print,Assign to Me,Acknowledge"
The above will hide the "print" task, "assign to me" task, and "acknowledge" task on whichever form it was set.
Note:Â Values must be comma-separated. These settings are also case-sensitive.
Service Request form before applying settings:
Service Request form after applying settings:
Versions
