User Guide: Add-In - Hide Templates
Add-Ins Overview
Hide Templates Download Link
The latest version 1.1.0 of this Add-In can be downloaded here.
Note: This version of the Add-In is built and tested against version 12.0.0 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Hide Templates Summary
The Hide Templates Add-In allows for templates in the +New drawer to be hidden based on a list of configurable prefixes. The Hide Templates Add-In works best with templates that follow a solid naming convention. For example, "Company - Type - Class - Name" where 'Company' would be your standard Company prefix, 'Type' is a grouping to show or hide this templates (Request Offering Template, Automation Template, New Drawer Template etc), 'Class' is the SCSM class the template is a type of and 'Name' is the Template Name.
Note: This Add-In will auto hide all Out of Box Templates such as "Incident portal template" or "Publish Offering". You can configure the settings to hide further Templates.
Key
Description
Default Value
PrefixesToHide
A comma separated list of prefixes to be used for targeting templates to hide from the +New drawer
PrefixToShow
A prefix to be used for targeting templates to show in the +New drawer
PrefixLength
The number of characters to remove on show templates to remove prefixes and clean up the view
0
Testing and Validation
    1. Verify the following:
      1. In the developer console (open up a browser > dev tools > console), you see that the Hide Templates Add-In is loaded
    1. Verify no error messages
Examples
With the Add-In disabled and the naming convention is configured, the +New Drawer looks like the following. Even the Out of Box Templates are shown.
With PrefixesToHide set to "Contoso - Request Offering Template - ", the template "Contoso - Request Offering Template - SR - Hardware Request" is hidden so that it can no longer be selected.
With PrefixToShow set to "Contoso - New Drawer Template - ", the template "Contoso - New Drawer Template - SR - Quick Service Request" is still shown.
With PrefixLength now set to 37, (the length of "Contoso - New Drawer Template - SR - "), that amount of characters is removed leaving the list looking very clean. Even the "SR - " is removed which is not part of te PrefixToShow to allow for different template classes to use the same settings.
Versions
