Add-Ins Overview
My Approvals Page Download Link
Note: This version of the Add-In is built and tested against version 12.0.0 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
My Approvals Page Summary
The My Approvals Page Add-In allows for the quick and easy approval or rejection of all currently assigned Review Activities as well as the ability to view inactive Review Activities and their decision status.
There are no settings for this Addin
Activation
Once the Add-In is activated through the Add-Ins page, a navigation node will need to be created in Navigation Settings pointing to /view/MyApprovalsPage
Testing and Validation
If experiencing issues, refer to KB Article 2568 here for overall Add-Ins troubleshooting steps
Run through the Add-In’s functionality with default settings.
Verify the following:
In the developer console (open up a browser > dev tools > console), you see that the My Approvals Page Add-In is loaded
As you change settings, go through the above again with browser console open
Verify no error messages
Verify your changed settings behave as expected
Examples
By clicking the Approve or Reject button inline with each activity, you can quickly approve or reject an activity and add a comment
By checking the Show Inactive Work Items checkbox, you can view previously completed Review Activities and their Status and Decision
Versions
