User Guide: Add-In - Resolve IR Task
Add-Ins Overview
Resolve IR Task Download Link
The latest version 1.2.0 of this Add-In can be downloaded here.
Note: This version of the Add-In is built and tested against version 10.2.0 of the Cireson Portal. It is recommended you are using that version or higher with this Add-In
Resolve IR Task Summary
The Resolve IR Task Add-In allows organizations to customize which fields are set when an analyst resolves an incident.
Key Description Default Value PlaceTaskAfterDetermines where it is placed on the Task pane. By default it is placed after the "Change Status"" task.Change StatusMinDescriptionLengthSets the minimum number of characters required for the Resolution Description in order to Resolve the Incident.0DefaultResolutionCategoryIdBy default it is set to the "Fixed By Analyst" guid.c5f6ada9-a0df-01d6-7087-6b8500ca6c2bActionLogCommentTitleThis sets the title of the action log comment that is added to the Incident when it is Resolved from the task.Record Resolved
Testing and Validation
    1. Verify the following:
      1. In the developer console (open up a browser > dev tools > console), you see that the Resolve IR Task Add-In is loaded
      2. This task appears directly after the "Change Status" task
      3. There is not a minimum character requirement for resolution description
      4. The Resolution Category defaults to "Resolved By Analyst" in the pop out window
      5. The action log comment is set to "Record Resolved" after completing
    1. Verify no error messages
Examples
Task showing in Task pane
ResolveIncident Task pop-up window
Action Log entry after Resolution
Versions
VersionRelease NotesLink1.1.0First ReleaseDownload1.1.1Fixed Default Settings BugDownload1.1.2Fixed HTML Closing TagsDownload1.2.0Localisations and other fixesDownload
