Azure AI (Manually Deploy)
With integration to OpenAI on Azure, Tikit Virtual Agent can provide generative AI responses based on documentation you upload. Generative responses use your uploaded documentation as a means to “learn” how to best provide a response. With generative responses, answers are unique and vary based on slight differences in how you prompt Tikit Virtual Agent.
Generative responses will be used when no configured Knowledge is found in your Knowledge Base. This ensure responses you’ve configured (KB or Templates) are returned first before a generative response is attempted to be returned.
OpenAI on Azure is deployed in your tenant, so your data stays with you. This article will walk you through registration, deployment, and configuration. This integration makes use of three different Azure resources - OpenAI, Azure Search Service, and Azure Blob Storage.
Deploy OpenAI
To begin integration, go to the Azure Portal and create a new resource.
1. Choose “Create a Resource”
2. Then search for “OpenAI” and then click “Create”
3. Choose where in your Azure tenant this resource will live
Subscription: The Azure subscription your OpenAI instance will be deployed in
Resource Group: A Resource Group is akin to a folder on Azure. Similar resources can be grouped together to help view their total cost, and permissioned based on a Resource Group. Either use an existing one, or create a new one such as “GenerativeAI”
Region: The Azure region/datacenter where this resource will reside. Locations geographically closer to you will have faster response times
    – NOTE: We have received reports that deploying specifically to the “West US” region will prevent the integration from working with Tikit. As such, avoid using West US when deploying Open AI into your Azure Tenant.
Name: The name of your Open AI resource. The resource can be named anything so long as it is something you can easily find later. Such as:
    – TikitOpenAI
    – TikitDocumentAI
Pricing Tier: As of this writing, S0 is the only tier that can be selected
4. Choose “All networks, including the internet, can access this resource” as Tikit will need to be able to access this Azure resource
5. Finally, add any Tags on this resource if you wish. Then Review, and Submit
Configure OpenAI
Once the resource has been successfully deployed on Azure, you can now configure it and upload documentation in Azure Open AI Studio.
1. Navigate to Chat and click on “Create new deployment”.
Set the deployment name to TikitProd. If you set this value to something else, make a note of it to use as the Deployment Name in the Tikit settings later.
Then choose gpt-4.1-mini as the model and click "Confirm".
Then fill out the following form:
Deployment Type: Choose Global Standard
Then click on "Create Resource and Deploy"
2. Next, it’s time to upload documents you want to use to train Open AI. In Chat, select “Add your data.”
3. In the “Add data” menu:
Select data source: Upload files (preview)
Subscription: Choose your Azure subscription
Select Azure Blob storage resource: Choose or Create a new Azure Blob storage resource
    – If you are prompted to “Turn on CORS” for the Azure Blob, click the button to “Turn on CORS”
Select Azure AI Search resource: Choose or Create a new Azure AI Search resource
    – Free tiers of Azure AI search cannot be used. You must use at least the Basic pricing tier.
    – The Basic Tier offers 15gb of document storage
Index Name: tikitopenaisearch
    – If you choose to call this something else, take note of it as it will be required later
4. Upload your documentation. This can be text, html, markdown, pdfs, Word documents, or PowerPoints. Each file can be no greater than 16mb.
5. Data Management
Search Type: Keyword
Chunk Size: 1024
6. Next, select “API Key” and click Next
7. Finally confirm your configuration and select “Save and close”.
Open AI on Azure is now processing your data and preparing to respond with generative answers. You can test this out within Chat Playground. Ask a question about some of the documentation you uploaded. The following image is an example wherein documentation about Tikit’s Quick Start guide was uploaded.
We can also use this example to approximate the cost given the above configuration where 1 Token is approximately 4 characters. Please note that costs will vary and the following is only an approximation. The most up to date pricing information is available on Microsoft's pricing page as seen here.
– $0.0000004 per input token ($0.0000004 x 57 = $0.0000228)
– $0.0000016 per output token ($0.0000016 x 348 = $0.0005568)
Schedule re-occurring OpenAI Training for New Documentation
If you're looking to:
  • Upload more documentation
  • Remove documentation
  • Run training on a schedule
  • Retrain OpenAI on demand
  • Automate file uploads from OneDrive or Sharepoint
Check out this related KB Article!
Integrate OpenAI
To configure integration with OpenAI on Azure. You’ll need several pieces of information to fill out the Azure AI configuration screen within Tikit.
1. First, you’ll set your Deployment Name and Index Name. Unless these were set to something else they are:
– Deployment name: TikitProd
– Index Name: tikitopenaisearch
2. Back in the Azure Portal, navigate to your deployed OpenAI resource. You can view all of your OpenAI resources using this link. Click into your configured OpenAI resource. Then expand “Resource Management” and select “Keys and Endpoint”
Here you will:
– Copy either Key 1 or Key 2 and paste it into “API Key” of the Tikit configuration page
– Copy the Endpoint and paste it into the “API URI” of the Tikit Configuration page
3. Next, navigate to your Azure Search service that you configured. You can use the following link to view all Azure Search Services. Select the Azure Search Service you used to configure OpenAI. Then copy the “Url” field into the “Search URI” of the Tikit Configuration.
Then select “Settings” and then “Keys”
Copy either the Primary or Secondary Admin key and paste it into the “Search Key” field within the Tikit configuration.
4. Navigate to the Storage Account used. Select “Security + Networking” and then select “Access Keys”. Use the following link to show all of your Storage Accounts. Select the one you used to configured OpenAI. Then, click to “Show” to view one of the connection strings.
Copy and paste the value into the “Blob Connection String” within the Tikit configuration page.
5. Finally, if you wish generative answers to provide downloadable links to articles the response was based off select “Allow citation file downloads”.
Click Save and you’re done!
