Enrich conversations with ticket data by searching & sending ticket details with the Tikit compose extension. Analysts can search for and share ticket cards with both users and other analysts in one-on-one conversations, group chats, or public channels. Analysts can also quickly create tickets at the touch of a button, but don’t forget about the Tikit Virtual Agent’s ticket deflection.
How to view the Tikit compose extension
The Tikit compose extension can be found by clicking the Tikit icon in the message compose area of Teams.
To open the Tikit compose extension in Teams:
Select the Tikit icon in the message compose area.
Not seeing a Tikit icon? Check out the steps below to find and pin the Tikit compose extension.
Tikit Compose Extension Select the Tikit icon to open the extension to search for tickets or add a new ticket.
Search Search for tickets, with optional filters:
Status s:
Category c:
Assignee a:
Tags t:
Add Ticket Quickly create a new ticket on the fly.
Tickets Select a ticket to add it to the compose box.
How to find and pin the Tikit compose extension
The Tikit compose extension can be pinned to an analyst’s message compose box in Teams for quicker access to search and share ticket details.
To pin the Tikit compose extension in Teams:
Can't find Tikit as an available extension?Make sure that the Tikit Teams app is installed for the analyst.
Otherwise, the extension will only be available for posts in team channels where Tikit is installed.
In Teams, open a one-on-one chat, channel, or post to view the compose message box, then select Messaging extensions (…), find and right-click Tikit and select Pin.
The Tikit compose extension is now pinned to the compose box for easy access.
How to search and send a ticket with the Tikit compose extension
Analysts can quickly search for and share ticket cards with both users and other analysts in one-on-one conversations, group chats, or public channels.
To search for and send a ticket using the Tikit search compose extension in Teams:
Select the TIkit icon below the compose message box to open the Tikit compose extension. Active tickets will automatically be shown, but you can search for specific tickets in the Search Tickets field.
Enter your search in the Search Tickets field. Ticket search also supports filters:
Status: s:
Category c:
Assignee a:
Tags t:
Once a ticket card has been added to the compose message area the card can be shared with anyone.
You have successfully searched for and sent a ticket with the Tikit compose extension!
How to create a ticket with the Tikit compose extension
Need to create a ticket on the spot for a user rather than directing them to the Tikit Virtual Agent? Quickly create a new ticket from scratch with the Tikit compose extension.
To create a ticket with the Tikit compose extension in Teams:
Select the TIkit icon below the compose message box to open the Tikit compose extension, then select Add Ticket.
Enter in details in the New Ticket form, then select Create to save the ticket.
