Tickets
Analysts can find and work tickets in the Tickets page. The Tickets page provides agents the ability to view a list of tickets, see tickets in a Kanban board style or run analytics against tickets view the Reports view.
How to view Tickets
To view Tickets:
  • In the left navigation, go to Tickets.
  • Choose from List, Board, or Reports ticket views.
Tickets List
The list view provides a compact list of tickets. Select a row to view and edit ticket details. Select a column to sort tickets.
How to sort tickets
By default, tickets are sorted by Id in descending order. Select a column header to sort tickets by that field. Selecting a column more than once will toggle the order from ascending to descending.
How to filter tickets
Filter by view type using the first filter dropdown found at the upper right corner of the toolbar.
Narrow down the filter by selecting items from the filter dropdown list
Customize your Tickets view
To change the appearance of your Tickets view:
  • In the upper-right of the Tickets view, click Configure Columns.
  • In the dialog, select which columns you wish to include by checking the box next to the column name. You can rearrange columns in the pane on the right.
  • You can set the sort order of a column by clicking the icon at the right of the column name. The icon will change color and the arrow will indicate the direction of the sort order.
  • Click Apply and you will be taken back to your Tickets view where your column selections are now visible.
NOTE: The customized column views are now persistent and will be restored the next time you open Tikit in your browser. You can reset your view by opening Configure Columns and pressing the ‘Clear’ button on the right side.
Creating and Managing Views
As an Administrator, you have the ability to create and manage custom views that are available to everyone using Tikit.
  • You can create a new view by clicking Save View after customizing a default view (see above), or by selecting Add New View under the views menu.
  • Similar to filtering a view, you can select different Filters in the New View dialog to determine what items will be included in your new view.
  • The Customize Columns section allows you to select which columns will be visible in your new view.
  • Click Save to save your settings and be directed to your new view.
  • You can switch between views at any time by selecting it in the views dropdown at the top of the page.
  • You can use the Edit or Delete buttons to edit or delete a custom view.
  • Editing a view is similar to creating a new view, simply click Edit, make your changes and select Save.
NOTE: Custom views also have their own unique URL for easier direct-linking.
Tickets Board
The board view provides a Kanban with lanes using the the Group By dropdown. Select a card to view and edit ticket details or drag and drop cards into different lanes to update them.
Reports
Advanced ReportingFor more advanced reporting, check out our blog series on creating a Tikit dashboard in Power BI!×
The reports view provides several useful reporting widgets.
How to add a ticket
Analysts can not only view current tickets but also create new tickets from the tickets dashboard.
To add a new ticket from the Tickets dashboard:
  1. Select + Add Ticket to open the New Ticket form.
  1. Enter your ticket details and select Create.
How to edit a ticket
To edit a ticket from the Tickets page:
  1. Find and select a ticket to open the edit ticket page. Check out the following map and key for info on the edit ticket page layout.
  1. Delete Ticket Delete the ticket. Warning that once deleted a ticket cannot be restored. We recommend Closing a ticket instead to remove it from Active views.
  2. Take Assign the ticket to the currently logged in analyst.
  3. Apply Template Apply a ticket template to this ticket. To learn more, check out Manage Templates.
  4. Send Form Send the associated Template's Form to a specific user to fill out
  5. Change view for tickets list. Select a view for the tickets list:
    • All Active
    • My Work
    • Unassigned
    • Closed
    • Deflected
  6. Search Search for specific tickets.
  7. Ticket Summary A ticket summary card with quickly finding ticket information.
  8. Activity Feed Get the latest updates, search for specific changes, and add replies to the ticket with the activity feed.
  9. Requester Info View requester information and start an email or chat at the click of a button.
  10. Properties, Attachments, Form Answers, Approvals, and Tasks sections Update ticket properties by expanding the needed section.
  11. Comment Editor Add a public comment or an internal note to a ticket.
  1. Once on the edit ticket page, expand the Properties section on the right, update any property fields needed, then select Save to save your changes.
How to Send a Form
When a ticket has a Template applied that has at least 1 form associated to it, the Form can be sent on demand to a specific user from the top menu
Clicking "Send Form" presents the Agent with a series of options for choosing how someone else should edit the answer for the form.
  • How do you want to handle the form(s)?
    • Send Form to Requester
    • Send Form to Selected Affected User
    • Send Form to Assignee
    • Send Form to Selected Collaborator
  • Send Current Answers
Depending on the role of the user within the ticket, they will receive a notification from either Tikit or Tikit Virtual Agent to fill out the form. When submitted, answers will overwrite existing form answers. The ticket Activity however will display a full audit trail of all of the answers/forms that were changed. By default, the current answers to the form are sent with the form for the user to see and alter. This can optionally be disabled so the user filling the form out starts from a blank form.
How to add Collaborators
Collaborators are additional Agents that can be assigned to a ticket when work is needed to be performed by several Agents rather than a single one. You can add collaborators in the Properties section when editing a ticket. Simply select the Collaborators field and start typing a name. Select the correct name from the list that appears and click the Save button to add your collaborator.
Collaborators work just like an Assignee on a ticket and will see the assigned ticket in their My Work view along with receiving any ticket notifications as well.
Note: Collaborators are not available in the Teams Ticketing and Service Desk product plans.
How to add Affected Users
The Affected Users field allows you to add additional Requestors to a ticket similar to the Requestor. Affected Users will receive the same notifications as the Requestor when changes are made to the ticket.
You can add an Affected User by expanding the ticket Properties and selecting the Affected Users field. Start typing a name, then selected it from the name picker that appears. Click Save and your Affected User has been added to the ticket.
Note: Affected Users are not available in the Teams Ticketing and Service Desk product plans.
How to bulk edit tickets
To bulk edit tickets from the Tickets dashboard:
  1. Find and select one or more tickets from the tickets dashboard by using the checkmarks on the left of each ticket entry, then select the Edit button in the toolbar to open the Update Tickets form.
You may be familiar with selection idioms from other software but here are some quick shortcuts:
  • Use the checkbox in the table header to select or deselect all tickets.
  • Click and drag to select multiple tickets at once.
  • Hold the ctrl key to toggle selecting a single ticket.
  • Hold the shift key to select a range of tickets
  1. Once the Update Tickets form is displayed, enable and set the ticket properties that will be updated on all selected tickets. Any properties that are not enabled will be left as their original values in each ticket.
  2. When finished, select Update to save your changes.
How to Bulk Delete tickets
Find and select one or more tickets from the tickets dashboard by using the checkmarks on the left of each ticket entry, then select the Delete button in the toolbar.
When prompted for confirmation, select Delete to permanently remove the tickets.
How to view ticket activity
Analysts can see a full of ticket activity from the Activity tab while viewing ticket details. The activity feed includes the ticket conversation with replies from both analysts and the requester and a toggle for ticket history to view all changes to a ticket. Any attached files are also shown inline with the comments, as well as in the Attachments section.
To view ticket activity from the Tickets dashboard:
  1. From the Tickets dashboard, find and select a ticket to open the edit ticket page.
  1. Once on the edit ticket page, the Activity feed will display ticket replies and history.
Select Hide History to hide history and only show ticket replies.
Filter history by type by selecting a value from the dropdown and optionally entering input in the Search… field.
How to comment on a ticket
Agents can use the comment editor to add a public comment or an internal note to a ticket. Public comments are sent via notifications by default to the Requestor, Assignee (unless they are the one creating the comment), and any Affected Users or Collaborators. Internal Notes are visible only to other Agents and notifications will be sent only to the Assignee and Collaborators.
To add a comment to a ticket that the Requester and Affected Users receive via Teams or email, use the comment editor to create your comment and select Send:
To add an internal note to a ticket that the Assignee and Collaborators receive via Teams or email, create your comment and select Add Internal Note:
Internal notes are listed in the same place as public comments, and can be distinguished by the red lock icon at the top of the note. Internal notes are visible to all Agents, Super-Agents, and Administrators.
Additionally, it is possible to use the @ symbol to mention any Agent including ones that are not related to the ticket as an Assignee or Collaborator and they will be notified of the comment via automation. At mentions work in both public comments and Internal Notes.
It is also possible to drag and drop a file attachment into an At Mention comment to attach the file along with the comment.
If enabled in Ticket Configuration, Agents can edit and delete their own comments. Hovering over a comment displays these options.
Comments can be edited inline. You can cancel the changes, save them as a draft, or send the updated comment.
Deleting a comment prompts for confirmation. Once confirmed, the comment is permanently removed from the ticket.
How to view and add attachments
To add an attachment to a ticket:
  1. Once on the edit ticket page, attachments can be added by:
    • Drag and drop a file onto the page.
    • Expand the Attachments section on the right to view attachments, select Upload and then browse to and select the file to upload.
Congrats! You’ve added an attachment to a ticket and can now view and download the file from the Attachments tab. The file attachment will be added to the SharePoint site for the Triage channel.
Upload Disabled? If you see that uploading attachments is disabled, make sure that you've added Tikit to a team and the triage channel is set properly. For detailed steps, check out How do I resolve "Upload disabled" when viewing ticket details?
File attachments also show inline in the conversation history of the ticket. Attachments with comments are included together.
Files can also be dragged and dropped into the comment editor window when adding a Comment or Internal Note to a ticket. They will be displayed the same way in the Activity view as an attachment added with a comment via the method described above.
How to remove attachments
To remove an attachment from the Tickets dashboard:
  1. Once on the edit ticket page, expand the Attachments section on the right, find the attachment, and select its Delete button.
Congrats! You’ve removed an attachment to a ticket. Note that the associated file in the SharePoint site will also be deleted at this point
How to view and update form answers
For more details on templates and forms, check out Manage Templates.
To view the form answers for a ticket from the Tickets dashboard:
  1. Once on the edit ticket page, expand the Form Answers section on the right.
  1. Update the custom answers by entering info into the form then select Update Answers to save your changes.
NOTE: If updating a ticket property that was included on the form, it will also change that property on the ticket itself.
