Uninstall HelpBot
To uninstall HelpBot from Teams:
Log into the Teams Admin center and navigate to Teams Apps -> Manage apps
Select All Apps and enter “HelpBot” into the search box, you should see the HelpBot app listed.
Select the HelpBot app to open the application details.
Click the ellipsis in the top-right next to the application details and select Actions -> Delete to remove the app.
The HelpBot app is now removed from the organization.
Install Tikit Virtual Agent
To install the Tikit Virtual Agent, please follow our guide for Tikit TVA Setup.
