Bot Configuration
View and update settings for the Tikit app and Ticket Virtual Agent app via Bot Configuration.
How to view Bot Configuration settings
To open the bot configuration settings page:
  1. Open the Tikit web app at https://web.tikit.ai
  2. Once in the Tikit web app, select settings gear in the header, then select Bot Configuration.
How to update Tikit welcome message
When the Tikit Teams app is installed, Tikit sends a customizable welcome message. This message provides a quick introduction for your analysts and is a great place to include some initial suggestions or useful links to get started.
Plain text and limited markdown in Teams is supported. Please see available options for more details.
Text Style
Markdown
Bold
Bold
Italic
Italic
Bullet List
- Item 1\r- Item 2\r- Item 3
Numbered List
1. Green\r2. Orange\r3. Blue
Hyperlinks
[Title](url)
Default Group (Channel)
View the default Group (Channel), and follow the “here” link to change default.
How to install Tikit Virtual Agent to Microsoft Teams
Select “Install to Microsoft Teams” to install Tikit Virtual Agent (TVA) in your organizations app store
Follow the Tikit Virtual Agent Setup Guide for full instructions on how to deploy TVA to your organization.
How to update Virtual Agent welcome message
When the TVA Teams app is installed, Tikit sends a customizable welcome message. This message provides a quick introduction for your users and is a great place to include some initial suggestions or useful links to get started.
How to customize the Virtual Agent Help Card
When customizing your Tikit Virtual Agent help card, you can:
  • Define a custom header/body.
  • Embed Links/URLs to your respective company’s website.
  • Create buttons that trigger the following:
    • Knowledge Article: Creates a button to return a specified Knowledge Article
    • New Ticket: Creates a button to kick off the ticket creation process
    • My Requests: Creates a button to show the status of all your current requests
    • Template: Creates a button to return a specified template
    • Open URL: Creates a button to open a specified URL
Group Chat
You can control Tikit Virtual Agent's welcome message and whether or not to include a link back to the ticket.
How to control number of the number of responses returned
The Ticket Deflection Score threshold lets TVA know how and when to reply to a request in the following order:
1. Tikit Knowledge Base (Articles and/or Templates)
2. Optionally look to generative AI to construct an answer
3. Create a new Ticket
TVA’s confidence in an answer is known as the confidence score, a number between 0% and 100%. A score of 100% is likely an exact match, while a score of 0% means that no matching answer was found.
The recommended and default threshold is 65% but you may want to adjust it to balance between accuracy and coverage of questions:
  • The Score Threshold determines the minimum level of confidence, or the amount a question/phrase matches a Knowledge article phrase, for its associated response to be returned.
    •  NOTE: If the Azure AI integration is configured and no responses exceed the confidence level. Deflection will then search against your configured OpenAI instance for a generative response.
  • The Number of Responses controls how many responses are returned in a deflection for a user to choose from sorted from most to least confident
  • When the most confident response is greater than the following number setting alters the behavior of multiple responses as configured above. When the most confident response is greater than this threshold, only a single response is returned rather than a selection for a user to choose from.
