Analysts can view and edit entries to retrain the Ticket Deflection Knowledge Base from the Service Catalog page. Professional KB responses can be created with a WYSIWYG editor for Teams markdown formatting or even responding to user requests with a custom form with templates in Tikit.
Service Catalog Settings
To view and retrain the ticket deflection Service Catalog:
Open the Tikit web app at https://web.tikit.ai.
Once in the Tikit web app, select Service Catalog from the left navigation.
Hover over the labels or check out the following key section for more details.
Add Catalog Item Add a new phrase and response pair to Service Catalog.
Search Search for specific KBs by phrase or response.
Phrases Ticket deflection phrases. Phrases can include questions, statements, and key phrases with additional alternate phrasing to provide more conversational responses to users.
Response Ticket deflection responses. Responses can be Teams markdown or a custom form response.
Request Offering Link the catalog item to a request offering.
Service Offering Link the catalog item to a service offering.
Order Specify the position of the Request Offering within its Service Offering in the Service Catalog. Lower numbers appear first.
Edit Selecting a phrase will open the Edit form.
More Options Additional options, including Edit, View, Get Link and Delete.
Status The publication status of the Service Catalog item.
Created By User who created the article.
Modified By User who last modified the article.
Last Modified Date time the article was last modified.
Agent Only Article can be made available to only Agents, Super Agents, and Administrators.
Note Prior to the addition of the Created By, Modified By, and Last Modified fields, this data was not previously recorded by Tikit, and therefore, will not display for articles created before these fields were introduced.×
Add a Catalog Item
To add new items to the ticket deflection service catalog:
In the Service Catalog, select + Catalog Item from the toolbar.
In the Edit form, enter one or more phrases and the response. The response can be formatted text with Teams markdown or a custom form using a template, see below for both options.
Select a Status for the article. Articles in Draft or In Review status will not be available for end users through TVA.
If the response should only be available to Agents, enable Agent Only.
To display the article in your Service Catalog as a Request Offering, turn on Enable Request Offering.
To have one of your predefined templates automatically presented as the response, enable the Use Template option.
Editing Service Catalog Items
Keep ticket deflections up and analyst work down by retraining the knowledge base regularly with new items. Manage entries to include alternate phrases, useful responses, and even custom forms from templates.
To update existing items in the ticket deflection service catalog:
In the Service Catalog, find an entry to edit then open the Edit form by selecting a phrase or selecting More options (…) > Edit.
In the Add Catalog Item form, enter one or more phrases and the response. The response can be formatted text with Teams markdown or a custom form using a template, see below for both options.
Respond with an Image
To include an image in your response:
Click the Image symbol in the editor.
Paste the image link in the URL field and click Add.
Align your image using the Left, Center, Right controls.
Note that images must be hosted somewhere that end users have direct access to when viewed from Teams, for example an Azure static website or CDN. For more information regarding the creation of a static Azure website to host your images see this article.
Warning: Because using image files in Service Catalog articles requires anonymous, public access to the image file, customers should be cautious about sharing image files that contain potentially sensitive data.
It should be further noted that SharePoint does not allow for direct access of image files and, therefore, will not work for this purpose.
Respond with Teams Markdown
To respond with a message using Teams markdown, use the WYSIWYG editor to write the response. The editor supports Teams markdown formatting, including bold, italic, strikethrough, block quotes, code blocks, unordered lists, ordered lists, URL links, and images. For more info on Teams markdown, please see Use Markdown formatting in Teams.
Respond with Template
To respond with a custom form in Teams, enable Use template and select an available template from the dropdown.
If you need to create a Template, please reference the Templates KB article.
After phrase(s) and the response have been entered, select Save to retrain the ticket deflection knowledge base. Once retraining is complete, the Service Catalog page will reload and the HelpBot virtual agent will get to deflecting tickets with the new knowledge in Teams.
Service Offerings
Linking a Catalog Item to a Service Offering ties the user-facing request to the underlying configuration. Without this connection, tickets may not trigger the correct templates, lifecycles, or ticket assignment.
You can link Catalog Items to a Service Offering within the Visual Service Catalog in the end-user Requests Portal. While the portal defaults to a virtual agent experience, the Visual Service Catalog offers a more structured, easy-to-browse layout similar to a traditional help menu.
Best Practices
Use consistent naming between Catalog Items and Service Offerings
Test the flow by submitting a request from the Service Catalog
Edit Knowledge Thresholds and Multiple Responses
To edit the strictness of the deflection as well as the number of responses returned:
In Settings, under Bot Configuration, you can modify:
Score Threshold: How confident (with 100% being a perfect match) deflection should be, before returning a response.
NOTE: If the Azure AI integration is configured and no responses can be found within your Service Catalog. Deflection will then search against your configured OpenAI instance for a generative response.
Number of Responses to Return: When multiple responses exceed the confidence threshold, they can be returned as a single response. This enables users interacting with deflection to make their own choice as to which response (Knowledge Article or Template) they would like to proceed with
When the most confident response is greater than the following: In the event multiple responses exceed the confidence threshold and the most confident response is greater than this number. Only that single response will be returned.
You will also have the option to only return a single Knowledge response if it is higher than a given confidence score.
You can modify the response given when the virtual agent returns your multiple responses, as well as the message when no responses are returned and a ticket needs to be opened.
Service Catalog Status
Service Catalog articles can have a status of Draft, In Review, or Active. Articles that have a status of Draft or In Review will not be available via TVA. The statuses can be used to indicate a newly created article that may be incomplete or require further review before being made available in TVA. Active articles will are available in TVA.
Agent Only Articles
Articles marked Agent Only will only be returned for users with the Agent or Super Agent roles when interacting with the Tikit Virtual Agent (TVA). Agents can use this to keep internal articles that should not be viewed by end users or when testing and reviewing article responses before making them available to the rest of the organization.
Deleting Catalog Items
Need to permanently remove an entry in the Service Catalog over updating it with new info?
To remove in item from the Service Catalog:
In Service Catalog, find and select the More options (…) on the right side of an entry, then select Delete.
Select Yes to confirm deletion and retrain the ticket deflection service catalog. Once retraining is complete, the Service Catalog page will reload.
Synonyms
Adding Synonyms to Tikit can significantly improve the quality of responses in the Tikit Virtual Agent. Synonyms allow for more accurate matching of intent when chatting to the Tikit Virtual Agent. Synonyms are universal in that they are not tied to a specific article and will improve accuracy across all existing and future articles in the Service Catalog.
Examples
Some examples where you could use synonyms:
Word
Synonyms
broken
defective, needs repair
knowledgebase
knowledge base, kb
bluetooth
blue tooth, BT
How to Add Synonyms
To add synonyms, navigate to Service Catalog and click on the Synonyms tab:
Click the Add Synonym button. The Add Synonyms window will open. Enter your synonyms one at a time hitting Enter after entering each one. Then click Save.
Chat Studio
The Chat Studio experience is designed to allow a Service Catalog Reader or Admin to experiment with queries and responses to the bot without creating tickets or having to interact via Teams. This allows for the testing of new Service Catalog items and to ensure that end user requests will return the desired article(s).
Chat Studio can be configured to include various types of responses, including Azure OpenAI if configured in your environment. Each of the options is further outlined below.
Include Draft and In Review Articles Includes Articles and Templates with the status Draft or In Review in the results.
Include Agent Only Articles Includes Articles and Templates that have been set to only display for Agents.
Include Azure OpenAI Results Returns a result from the Azure OpenAI service, if configured, when no result is found in the Tikit service catalog.
Show Ticket Deflection Score Display the deflection score value when matching against the Tikit service catalog.
Ticket Deflection Score Threshold Functions the same as the slider found under the Bot Configuration settings. Changing this value only affects the results in Chat Studio and does not have any impact on the value set in the Bot Configuration settings.
Number of Responses to Return Functions the same as the setting of the same name in the Bot Configuration settings. Changing this value only affects the results in Chat Studio and does not have any impact on the value set in the Bot Configuration settings.
Note Including Azure OpenAI results in Chat Studio will incur costs on your Azure subscription.
